07-01-2015 09:26 AM
how to run labview software on any other computer which does not having labview software ???????
actually i have made the program in labview software but now our faculty told us to run the program on a hardware nopt containing labview software....
plz sir help me in finding out the solution....as it is the last step remaining in my practical....
07-01-2015 09:29 AM
You need to make an executable and installer. The installer will package the appropriate run-time for it. You will have to make sure to include any other necessary packages in the install.
07-01-2015 09:29 AM - edited 07-01-2015 09:31 AM
What type of LabVIEW license do you have?
If it's LabVIEW Professional, or higher (or your faculty bought the Application Builder add-on), you can build an executable that uses the LabVIEW Run-time environment.
If your install has the ability, use this.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-01-2015 12:30 PM
sir is there any direct way to download application builder trial version????
if yes den sir can u send me the link for dat???
07-01-2015 12:33 PM - edited 07-01-2015 12:34 PM
You can purchase it fron NI for $1500.
Misread it. Just download the trial version of LabVIEW. However, I think the built applications stop working after the trial period. (I can't remember.)
07-01-2015 12:47 PM
trial version of labview???????
sir i am asking for trial version of application builder??????
i m already using 1 month version of labview..........
07-01-2015 12:49 PM - edited 07-01-2015 12:49 PM
Well then you should already have the trial version of the app builder!!!???
07-01-2015 12:53 PM - edited 07-01-2015 12:54 PM
Have you tried the link i included above????
It will help you if you already have application builder installed.
Cheers
07-01-2015 03:47 PM
Yes I'm pretty sure you can make an EXE with the evaluation version of LabVIEW, but it will leave the Evaluation watermarks.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-01-2015 05:10 PM
Only LabVIEW 7 Evaluation does NOT include the App Builder. LabVIEW 8 and above Evaluation Versions include it and they have water-marked front panels. I'm curious if Bilko is right about the EXEs "expiring" along with the evaluation time. If not, isn't this a way to get free LabVIEW Executables forever without ever actually paying NI a penny? You would have to code your whole app within 52 days (7 initial + 45 extended) but then your app is free. Doesn't sound right to me.
http://digital.ni.com/public.nsf/allkb/862567530005F09C8625675F00711756
