how to read .rsl file
Hi
I am analysing VIs using VI Analyzer.After analysing i had saved the result.But now if i wants to read the result then a message popup showing( .rsl is not a valid labview file).
plz tell me, how can i read .rsl file
Thanking You
Raman
(3,076 Views)
Hi Raman,
You must use the Results Window of the VI Analyzer to view .rsl files.  You can get to it directly by going to Tools > VI Analyzer > Show Results Window.
There is no other way to view .rsl files.  If you want a human-readable document of your VI Analyzer results, you must export them as ASCII or HTML, which you can do from the "Export" button in the Results Window, or with the VIAn Easy Results.vi if you are using the VI Analyzer API.
Let me know if you have any other questions,
-D
(3,068 Views)
Respected sir,
                    My project needs real time biosignals which is in
the file format of RSL, How to read the same signal by LABVIEW?
(2,752 Views)
Your question is totally unrelated to this very old thread. Please start a new thread in which you provide some details on the format of these files.
(2,747 Views)
The tool is located here:
VI Analyzer RSL Exporter
https://decibel.ni.com/content/docs/DOC-26552
(2,675 Views)
Judging from his description, I think vino's RSL files are *not* VI Analyzer results files...
(2,666 Views)
