05-09-2014 08:56 AM
Hello!
I am working on a festo MPS PA compact workstation and I have connected the system to the PC using the EasyPort.
So far, I can send commands to the system to turn on some components like Pump, Heater, Pressure Valve. But the problem is that I could not read the data from the sensors at the system like the tank level and the temperature of the water.
attached is the vi file for what I have done so far
I would really appreciate your help!!
Thank you in advance
05-12-2014 10:18 AM
cise438,
thanks for the forum post. Are you not able to read any values? or are you getting incorrect values? Are the reads from the sensors digital reads or analog reads?
05-12-2014 10:36 AM
05-12-2014 11:06 AM
According to the code you posted I only see Digital read and writes occuring. is this correct?
05-12-2014 05:30 PM
Yes, that is correct. But also i have tried to use the same easyport function after changing it to (read Analog Input), and I attached an indecator, It did not work and I am not sure where to connect its reference.
thanks
05-13-2014 12:39 PM
cise438,
do you have an documentaion for the easyport activex control? unfortunately, i do not have access to the control.
05-13-2014 01:03 PM
is there an associated api or program that came with the MPS work station that would allow you to verify that the sensors are operational?
04-15-2019 09:39 AM
Hi
I hope that you are doing fine
Just can you please tell me how did you create those global variables and how to use the invoke node. Cause it only shows that i have 1 digout and 1digin but in the festo workstation i have more than that.
Thanks in advance
04-16-2019 09:45 AM
Hi Samidj72,
This is an old thread. I would suggest creating a new one to get some fresh eyes on your issue.
04-17-2019 07:30 AM
Hi JiwhanS
thanks for your response
i have my graduation essay this year and i have to control the festo work-station and i don't fully understand the activex control
can you please help me
or give me your email so i will be easy to contact you
and thanks in advance
