NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
Taki1999
Re: how to read and display a signal from my a miccrontroller (MCB1700) onto labview connected via a CAN port on a PXI machine
Is your target PXI a real-time machine?
I'm afraid I don't have enough experience with that remote configuration to know how to troubleshoot it.
If you can log on locally to the PXI which has the CAN card, you should be able to run the Bus Monitor directly.
If your target PXI is a RT machine, you should be able to modify the CAN Receive.vi to put outputs into a Network shared variable.
Member
fhaljauf
Yes, its a real time machine.
Any idea on how to modify the CAN Receive.vi to put outputs into a Network shared variable?
Active Participant
Taki1999
Been a while since I've worked with RT so I'm doing a little guessing from memory.
Replace the BaudRate and interface controls with constants.
In your RT Project, Add a variable to replace the Output Array 2.  Making the datatype variant should work and then your host.vi would be responsible for extracting the array back to the Output Array 2 format.
Build, Deploy your vi and shared variables.  Your host.vi should then poll the shared variable for display.
Member
fhaljauf
How do you do all of that?
Active Participant
Taki1999
Unfortunately, I'm very rusty with my RT knowledge.
This console viewer looks promising for debugging:
RT Console Viewer
My limited knowledge of RT was obtained here:
Getting Started with RT
The getting started document should have details of how to use Network Shared variables.
Member
Rdawg
Because you are using LabVIEW 2k11 and Windows 7, you will need to upgrade your NI-CAN drivers first.  2.7.3 is the first version that will support the new LV and Windows 7.
Start with that and then I think you'll be able to get farther on these steps
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n13:hardwareDriver...
Member
fhaljauf
I upgraded the NI-CAN drivers to 2.7.3 but i am still not able to see the option where i can select a channel and launch the bus monitor on MAX. What might be wrong?
I am just worndering, does  VISA Test Panel serves the same purpose as the Bus monitor on MAX?
Please help.
Member
ColdenR
Hello fhaljauf,
You will also need to install NI-CAN on your PXI chassis. Did you do that as well?
Colden Rouleau
Product Support Engineer | NI-RIO R&D | National Instruments
Member
fhaljauf
Yes i did.
I was just wondering, is the bus monitor something that needs to be installed as well. If so, can you please point me to the link where i can install it.
Also, what is the appropriate VI that i should use when creating a project to get access to the CAN ports?
Member
Rdawg
If you search NI.com for "CAN Bus Monitor", there are alot of resources that come up:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/CAN%20bus%20monitor/
Can I use Bus Monitor with RT system ::: http://digital.ni.com/public.nsf/allkb/6AF3AA9CE79365E386256F9E007E8CE9
Can I use BM with 2-port CAN::: http://digital.ni.com/public.nsf/allkb/257368380A4EE1FC86256C1B006E5F2A
Beyond that, you need to use the NI-CAN driver in LabVIEW to work with your card and get access to the channels etc.  As with most NI drivers, you typically open a reference to the card, and then extract the channels etc.  Check out the example finder in LabVIEW
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
