10-20-2008 11:59 AM
I have Labview 8.5. I have an xml file (Database) that contains data from sensors. The data doesnt conform to the LabView's xml schema we have our own schema for the data. is there a way to extract the digitized waveform data from this xml file by using our own xsd file?
Shoaib
10-20-2008 12:34 PM
10-20-2008 01:16 PM
10-20-2008 04:00 PM
I got the JKI easyxml but I have a question. How do i convert the xsd file to Labview Data Type variant? is there an easy way? i am thinking that i will have to create a cluster that matches the xsd file and then the parser will be able to read the xml file and output the data in the same format.
I am very very new to XML so any help will be appreciated.
Shoaib
10-20-2008 10:39 PM
Hi Shoaib,
I replied to your post on the JKI Software forums. Please post your XML file, there, and we'll try to help you out.
-Jim
10-20-2008 11:19 PM
I am attaching the xsd file here since I am not sure if by attaching the actual 3MB XML file i will be giving away any info that im not supposed to.Please rename the attachement to fmd.xsd
All i'm looking for is to somehow get the data defined by the following
10-21-2008 10:54 AM
Jim,
heres the file i tried to de-identify it as much as possible. I am interested in the raw data in the xml file. The incoming xml files may have data for multiple episodes like in this example xml.
10-21-2008 06:34 PM
