04-20-2013 03:12 PM
Hello Everyone,
What I am doing now is plotting the power vs. rpm. I have plotted the rpm vs. time and power vs. time. I have two while loops for each parameter because one while loop uses the old DAQmx setup and the other uses the DAQ Assitant to get the power. I am not sure on how to plot the Power vs. RPM.
Please find below a picture of the block diagram. I have used the excel method but I want an XY graph where the X is RPM and the Y is power output. I have looked at examples on how to use XY graph but were not of use.
Any help would be appreciated.
Marwan
04-21-2013 11:42 AM
Hi Marwan,
did you look at the context help for an XY graph?
It looks like that:
It says: bundle an array containing X values with an array containing corresponding Y values to a cluster and wire it to a XY-graph...
You may build an array of plots too...
