how to make delay under 1ms
Hey all,
I want generate pulses from parallel port with delay under 1ms , but when using the wait function in real time module and put 10 microsecond it works like 1 ms delay
help please,
(2,267 Views)
Accepted by topic author mohamedaboauf
Hello Mohamed,
Before posting any query first try to get solution using National Instruments search engine..
There are a lot discussion with the same query.
Discussion 1
Discussion 2
Discussion 3
Discussion 4
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,241 Views)
And if the built in search doesn't work well, and it usually doesn't, you can always use google. Just put site:forums.ni.com after your search term to limit it to the forums.
LabVIEW 2012
(2,212 Views)
