03-15-2017 07:02 AM
i want to make flashing LED. how to do that?
Asif
03-15-2017 07:09 AM - edited 03-15-2017 07:10 AM
03-15-2017 09:26 AM
Hello Aisf138,
As GerdW says, you can use a While Loop to change the value of the LED (True/False) for each iteration using Shift Registers. In Addition, you can add a Wait function to control the "Blinking Time". I share with you a VI Snippet to do this app.
Regards!!!
Sebastian.
03-15-2017 12:59 PM
Any details? NI is dealing with many kinds of flashing LEDs including
Semiconductor manufacture control to make LEDs that can flash.
Controlling NI and 3-d party current sources to flash LEDs
Design of PCB to make LED driver to flash LEDs
Ethernet hubs flash active LED when transmitting data, if you write network communication, you have flashing LEDs
Above 2 software solutions
ETC...
03-15-2017 11:52 PM
Thanks Dear
its working. but i want to to start blinking by logic (0 or 1) just say by toggle switch.
how to do that.
Asif
03-15-2017 11:54 PM
I want one Boolean indicator (LED) to blink when i press toggle switch. i actually want to blink it when logic 1 on any input bit of PLC high.
Asif
03-16-2017 01:57 AM
Hi Asif,
Use the blinking property of the LED indicator, just connect your switch…
Read "any input bit" of your PLC, OR those bits, wire the result to the blinking property of your LED indicator…
03-16-2017 09:49 AM
Hi Asif138,
This VI Snippet makes a blinking Led when you press toogle switch using Event Structures and Property Nodes.
Regard!!!
Sebastian.
