how to implement following equation with limits in labview
how to implement following equation in labview
y (n+1) = x(n+1)  if  n(mod T) = 0 and ∏ Q(n-iT) =1 where ∏ denotes
multiplication, its lower limit is i=0, upper limit is L
              x(n)      otherwise
where T is length of comparison intervals and L is number of comparison.
Message 1 of 12
(2,653 Views)
How do you receive your values for x and Q? Do you get all the values at once, or are the values streamed in real-time?
What is n(mod T)?
Certified LabVIEW Developer
Message 2 of 12
(2,639 Views)
Hi....
I have added a picture to try and see what you are saying.
is the picture correct ?
Do you have the X array and you are creating the Y array ?
Do you have initial values for one of the arrays ?
can you give a reference to the article you are using ?
Message 3 of 12
(2,630 Views)
yes, the limit applied are correct but the limits are of Q(n-iT) ,   n(mod T) =0
 i just want to know how to apply limits and how to give two conditions
Message 4 of 12
(2,614 Views)
X(n) is vector which change its value at every instant.
n is number of samples. n(mod T)  = 0 means modulus of length of comparison interval is zero
Message 5 of 12
(2,610 Views)
Do you have any code of what you have tried?  I'm also wondering where X and Q are coming from.  Things that might help you is the modulus can be calculated with the Quotient & Remainder function (the remainder is the modulus) and there is a Multiply Array Elements.
GCentral
Message 6 of 12
(2,589 Views)
OK.....
more questions and I will try to create an example.
1. What is Q ?
2. What are ranges of the indexes, do we have X0? do we have X1 ?
(notice that in order to know Y0 we should have X(-1)
3. the multiplication is also (mod T) ?
Message 7 of 12
(2,568 Views)
OK... without knowing too many details, about what is Q and if there is Y0 or X0 ,
here is an example that will show you "how to apply limits and how to give two conditions"
tell me if it help in any way
Message 8 of 12
(2,552 Views)
i am sending you detail of equation in attachment
Message 9 of 12
(2,528 Views)
my labview version is 2010, so VI sent by you could not be opened so kindly send me in 2010 version
Message 10 of 12
(2,527 Views)
