NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
EricDouai
Accepted Solution
how to get the real time controller download file for cRIO 9074
Hello
I am a beginner of LabView. Now I do a project in school with cRIO 9074.
My problem is that I have deleted the embedded controller system by fault. But in the Measurement and Automation software I didn't find the controller sysyem which have the fonction of monitor on line. How can I download the load file?
Wait for your help, and  thank you for your help very much.
Member
christian_w
Re: how to get the real time controller download file for cRIO 9074
Even if you format the cRIO system it should be found by the MAX and by opening the Software config you can reinstall the system files assuming that they are installed on the connecting system (PC).
So you have to use the MAX to setup the cRIO. Maybe it is of help to set the DIP switches to NoApp and IPReset first.
Hope it helps
Christian
Member
EricDouai
Thank you very much for your help.
Now the problem have been solved. Thanks again for your help.
Eric Douai
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
