10-11-2005 10:18 AM
10-12-2005 01:06 PM
Hi Silverhawk,
If you can acquire the correct 2 Volt values in the test panels of the DAQ assistant, then there is something that I want you to try. Create a task in MAX to acquire your data and run a test panels to make sure that you are receiving the correct values. If these values are correct, then go to LabVIEW and place a DAQmx Task Name Constant on the block diagram. Select the task that you created, right click the Task Name Constant, and select Generate Code >> Configuration and Example. Run this program and let me know if you are now acquiring the correct data.
Hal L.
