weizbox wrote:
> Im currently making a little automation program for a server we have
> to run simulations. I had it set up to monitor user named directorys
> to see if new files where added, when they did they executed and
> notified the appropriate user. With adding more computers to the
> network, i do not want to have to modify the code to look at more
> folders, and create a new folder each new computer we add.
> I was wondering if there is some way you can find out the original
> location of a file if it were given to you over the network. For
> instance if computer A drops a simulation file in Server X, how can X
> know that the file came from A? Keep in mind id like to keep this is
> simple for the users as possible, aka no login or anyhting, just want
them to be able to dump they're files on a shared network folder.
Windows does not maintain in itself any information as to the original
location a copied or moved file may have been originated from. The only
way I would see that to be workable is by including some information in
the header of the file itself which then gets examined by the reading
application on server X.
Rolf Kalbermatter
