how to get max reading from waveform
Reading data from ir thermometer that cycles 60 hz .  Waveform goes from temp reading 0-+10v to zero every cycle. How do I read the max temp and output to indicator.
(2,442 Views)
How are you reading in the data from the thermometer?
Do you want the max from the last cycle or over a couple of cycles?
Why are you looking for the max rather then the average?
Do you have any existing code that we can see?
How is the temperature output?
(2,429 Views)
