how to fix constant width in table column.
hi.
       how to change table all column width programatically ..i try to change but only 1'st column  only change.
(3,311 Views)
Hi Gokul,
first select the column you want to set width (using ActiveCell property), then change the width…
(3,296 Views)
hi, i want to change all column width that i am using -2 but 1'st column only change...
(3,268 Views)
Accepted by topic author GokulGKM
(3,224 Views)
ActiveCell "coordinates" usage can be a bit confusing, it is good to keep this link as a reference:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvprop/multcollst_active_cell/
(3,189 Views)
