how to express vibration in time domain
hi
i am acquiring accelrometer values from the sound and vibration signal simulator box
the values are some what like this
x=2.54656.. y=2.23456....
i want to plot the values in the time domain and later i want to find the magnitude and the frequency ie., in frequency domain
how can i do that..
Message 1 of 8
(2,521 Views)
Hi irfan789,
There is an example in NI Example Finder which you can look into. Go to LabVIEW >> Help >> Find Examples... >> Go to Search and type keyword "accelerometer". Presuming that you want to find the FFT value of your accelerometer readings, there is an example called: "Multifunction FFT (DAQmx).vi". You can refer to that code or other vis from the search.
Or you can look into this link if you plan to use Express VIs: http://www.ni.com/white-paper/13042/en/
Hope that helps
Warmest regards,
Lennard.C
Learning new things everyday...
Message 2 of 8
(2,506 Views)
Also consider the NI Sound and Vibration Measurement Suite, on-line HTML manual. It has concepts as well as function reference:
http://zone.ni.com/reference/en-XX/help/372416G-01/
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 3 of 8
(2,483 Views)
i have gone through few functions for performing FFT
i found two functions one is FFT point by point and other is FFT with signal
i am getting a raw data from accelerometer which on shouldi use for determining harmonic analysis..
Message 4 of 8
(2,461 Views)
Hi irfan789,
Depends on how you want to analyze your data. Either you want to analyze the data point by point or you want to send in a batch of data (signal). Is your raw data in the form of 1D arrays or DBL?
Using Fast Fourier Transforms and Power Spectra in LabVIEW
http://www.ni.com/white-paper/4541/en/
There are some additional examples in NI Example Finder like "Harmonic Analyzer Measurement.vi" and "FFT and Power Spectrum Units.vi" which you can refer to and see if that can assist you in your applications.
Warmest regards,
Lennard.C
Message 5 of 8
(2,451 Views)
hello sir,
your question:-
  answer:- my data is DBL ..
So how should i proceed?
Message 6 of 8
(2,436 Views)
hello sir,
your question:-
Message 7 of 8
(2,427 Views)
Hi Mashfique,
Like I have mentioned to irfan789 that it depends on how you want to analyze the data. If you want to take a batch of data then analyze it to FFT, build array of a fix size and pass it to the FFT that takes signal as input. You can refer to the examples I have mentioned in my past post on how to pass an array of values to the FFT.
If you want to know the FFT of data point by point, then pass the DBL straight to that FFT but specify the length (default is 100 so you cannot pass the number of data less than 100).
Warmest regards,
Lennard.C
Message 8 of 8
(2,399 Views)
