10-17-2014 01:12 AM
In my VI, I use a table control. and I create a run-time shortcut menu for it. The Items is "Modify" and "Add New". Now I want to disable Item "Add new" some times. So is it possible to get the shortcut menu ref. in order to disable "Add New" Item?
10-17-2014 01:41 AM
06-10-2015 07:52 AM
Is there a way to disable the "right click" short cut menu in the header? I do not want the short cut menu active in the header. I only want the shortcut menu working in the "body" of the table, where the data is located.
