-------------------------------------------------------------------------------------------------------- Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success. --Ranjeet
The target system also needs to have the correct LabVIEW runtime engine installed. It can be installed seperately or included with the installer that you create for the executable.
(Note that you need LabVIEW professional or add the application builder. For example LabVIEW base, full, or the student version does not have this functionality.)
