02-05-2007 01:59 AM
02-06-2007 05:28 PM
Hi 3den,
Bulk transfer is actually the default transfer mechanism for USBTMC, so you should be fine there. Furthermore, the block outline that you described is also appropriate for this type of communication. Hopefully this helps!
02-07-2007 10:40 PM
02-07-2007 10:45 PM
02-08-2007 12:41 AM
02-09-2007 02:12 AM - edited 02-09-2007 02:12 AM
Message Edited by 3den on 02-09-2007 02:13 AM
Message Edited by 3den on 02-09-2007 02:14 AM
Message Edited by 3den on 02-09-2007 02:16 AM
02-12-2007 02:28 PM
Hi 3den,
When you said that you created the device driver - did you go to Start>>Programs>>National Instruments>>VISA>>VISA Driver Development Wizard and follow-through the steps there to configure your USB device for use with VISA? You'll need to do this before your device is listed as a VISA Resource. There are step-by-step instructions for using the VISA Driver Development Wizard here.
Make sure that you can check in the Measurement and Automation Explorer under Devices and Interfaces to see your USB device there after following this Wizard. Hope this helps!
