08-01-2015 06:44 AM
Hi friends,
I created database table creation for users list. That is working fine. And I also get back the data which is I stored earlier and I displayed table format in front panel. Now I want delete any one row, this is not an order wise, for example now I have one table, it has total 7 rows and 5 columns available. Now I want delete 3rd row by using selecting the row (i.e. click anywhere in that row and press button) that time that row will be delete in database. Then remaining again will be store in the database.
I want this way is this possible or not?
Thanks Advance
Arunkumar M
India
Note: I am using LabVIEW database connectivity toolkit
Database : Ms access
Sorry for my grammatical mistake
08-01-2015 07:49 AM - edited 08-01-2015 08:04 AM
@arun575 wrote:
Hi friends,
[...] Now I want delete 3rd row by using selecting the row (i.e. click anywhere in that row and press button) that time that row will be delete in database. Then remaining again will be store in the database.
Rather than storing the data in the database, simply delete the record you deleted from your FP indicator and reload the indicator from the database. (The first column in my database is named ID - autoindexed, primary key)
EDIT - That blue sub-vi is https://lavag.org/files/file/60-array-point-to-rowcol/
08-01-2015 08:47 AM - edited 08-01-2015 08:57 AM
You do have a primary key on your table right? Always have a primary key.
If you have a primary key you might also consider whether you really want to delete a record. If you delete a record you could also end up deleting all the record relationally associated with that record. Better to have a column called active_user or the like and simply set it to false when someone leaves. To populate your onscreen table you simply add a clause to the query that says: WHERE active_user = 1
Mike...
08-06-2015 11:54 PM
Thanks for replies .......
I got answer.......
Thanks again.......
Arunkumar M
India
