08-25-2015 08:12 AM - edited 08-25-2015 08:25 AM
hello every one ,
i have one vi that contain a table indicator that read out the data from data base.on the front panel i want to add a button which on clicking pop up a window in which user can add item in tables of database ,the user will fill up the data and click on ok button .on clicking ok button the item will appear in the table of the database.and the window close .
please help me in creating this ok button so that the item can be added into the list after clicking it as well as it will exit the pop up window.
i am sorry if i ask something stupid ,because i am new to labview and using it in my first project .i have googled before about the pop window but all i end up into a mess.please help me .plesae..!!
thanking you ,
Solved! Go to Solution.
08-25-2015 09:42 AM
Create a subvi and set the window to 'open front panel when called' and 'close afterwards if originally closed' in the VI properties under 'window appearance' (or use the front panel open / front panel close methods inside your subvi). You will need to use the event structure to detect when someone has clicked the OK button to then add the item to the list. You will probably want a cancel button which just closes the window as well 🙂
You can also turn off scrollbars/menus etc. and set the window to floating/modal to make it look more like a popup dialogue.
08-26-2015 12:18 AM - edited 08-26-2015 12:23 AM
hello sam
i am not clear how to use the event structure still now.i do it but it donot work .Could you give me a sample vi for making the pop window .please make sure i am using version 13 .please reply me soon
i have attached my vi which i want to make the pop window.Will you create the sample using this vi.
thankyou for your precious advice
08-26-2015 02:07 AM - edited 08-26-2015 02:07 AM
See the attached VIs; I have attached the example to how you can add the row to the table.
My example is not an ideal but will give a quick idea about how you can add the row using pop up window.
Don’t forget to use window appearance as ‘Dialog’.
curreltly my code is only adding the 0th row,
Further you need to see to which row you should add the output of the form ?
Table properties might help you
08-26-2015 02:09 AM - edited 08-26-2015 02:09 AM
Also see attached VI here, which I have used for my previous project. From this VI you can get the following ideas,
08-26-2015 03:31 AM
thankyou so much .but before your reply i was succesful in finding my solution,here adding the vi.
- When and how to update the data upon pressing Ok button
- This also has cancel button in case of change in decision
- Panel close event and further save changes “Yes, No, Cancel”
