how to convert string matrix to a matrix that can be potted using plot3dl function in scilab
Hello everyone,
When I try to put this matrix named power into the "plot3d1 (x,z,power)" function of scilab as one of the arguments, I get an error- "!--error 246
Function not defined for given argument type(s),
  check arguments or define function %c_plot3d1 for overloading. "
I think it has a problem with the type of the matrix "power" which is string type.  I'mr reading the matrix "power" from an input csv file.
the other two aguments- x and z  are of the type "double".
can anyone suggest possible solutions?
(2,397 Views)
What does this have to do with LabVIEW?
While I have never used scilab, I suspect that your idea that the plot function does not accept strings is correct. In LabVIEW it is easy to read a csv file and convert it to a numeric array.
Lynn
(2,361 Views)
