how to convert "True" string to boolean
muks wrote:
Haha muks- isn't LabVIEW great; it tempts you to overcomplicate things!!
Absolutely............... :smileyvery-happy:
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Quote from Albert Einstein
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 17
(4,522 Views)
Opposite direction can also mean you dont have the required thing to face the complex things
Message 12 of 17
(4,513 Views)
Another way.
Message Edited by Ravens Fan on 08-06-2009 10:55 PM
Message 13 of 17
(4,475 Views)
Accepted by Chris_Cilino
Scan From String
Message 14 of 17
(3,662 Views)
Very nice tight code for string literal "TRUE/FALSE" to boolean conversion. Who would've thought of it that a Scan from String function does this instead of the Type Cast function?
Using a Type Cast function with a Boolean constant results in all TRUE or all FALSEUsing a Type Cast function with a Boolean constant results in all TRUE or all FALSE
Using a Scan from String with a Boolean Type input results in correct conversionUsing a Scan from String with a Boolean Type input results in correct conversion
Message 15 of 17
(2,612 Views)
Hi Relativity,
Anybody who has read the LabVIEW help for FormatIntoString, ScanFromString and TypeCast would have known this difference…
Message 16 of 17
(2,589 Views)
Well, DUH!
But even your answer wasn't the best or tightest code GerdW. Keep reading 'em LV Help files! 😉
Message 17 of 17
(2,562 Views)
