how to convert a 1D string to an array?
The string is in binary and I want to convert it to an array so I can convert it to a digital waveform of some sort.. but using the string to byte array vi is not possible since it is in 1D and destination is sink. How do I fix this? thank you!
(2,916 Views)
Accepted by topic author meere
Hi meere,
is there a specific reason to use MathScript to create a sine wave and convert it to some "digitized" waveform?
Why not use simple functions from Signal processing functions palette?
To answer your question:
(2,896 Views)
Thank you for your help GerdW! The VI you used seems different from the one I found.
btw, im using Mathscript because i'm not that familiar with using the signal processing vis but the project is required to be implemented in labview
(2,892 Views)
HI meere,
I'm converting strings to numbers using ScanFromString.
You use some File function: why do you search functions in the file functions palette when you want to convert strings?
(2,883 Views)
