how to control music player commands like start, pause, stop, mute etc using labview
i have acquired gestures using accelerometer .  how to use this gesture to control music player commands like play,stop,pause, mute etc...
(2,874 Views)
Personally, I would create two processes that are running in memory together. One receives the accelerometer data (however you do that), while the other controls the player (however you do that). When the accelerometer task identifies a gesture, it would fire a user-defined event that causes the player controller task to perform the associated operation.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,798 Views)
