08-03-2012 03:57 AM
i have designed a VI in which there are three different algorithms applied in case structure then common for loop is applied and at one time graph of selected algorithm is displayed.
i want to run all the three algorithms simulataneously and display all graphs on single graph.
08-03-2012 04:36 AM - edited 08-03-2012 04:39 AM
you can change the enum array constant to an control and also pick the algorithm to compare...
08-03-2012 05:05 AM
kindly send Compare VI in 2010 version. my all algorithms are going to single for loop which will run one at a time how i can compare all algorithms
08-03-2012 06:14 AM
well, the picture should tell you all you need 😉
it took me 5 minutes to draw it ... redraw it made in close time 😉
or post your vi ....
08-03-2012 09:32 AM
If you want to compare all three at the same time, why would you even do something as silly as a case statement. That makes no sense.
