how to change tab control page order?
I am trying to change the page order of a tab control, To control the pages.
It is posible to do this in any way?
thank you .
(2,855 Views)
My guess is that since it's an enum, it can only be changed in edit mode.
Bill
CLD
(Mid-Level minion.)
(2,840 Views)
(2,812 Views)
I have already seen this topic but I have not found the solution I am looking for,
Especially that I did not find, an invoke node (method) "rearrange pages".
(2,791 Views)
Accepted by topic author Sarah_LAB
Right click on tab control >> Create >> Invoke Node >> Rearrange Pages
As mentioned in the help, it requires VI scripting. I have never used this method.
(2,788 Views)
Thank you I found it.
It is for what if the method is not used when the executing program?
(2,776 Views)
Hi Sarah,
you can use VI scripting to create new VIs or edit existing ones programmatically.
VI scripting is not allowed/possible in executables as you cannot change compiled code!
("Compiled" in the sense of "fixed in an exectuable", as LabVIEW always compiles the VI… Also executables call the RunTimeEngine which doesn't support scripting.)
(2,774 Views)
