06-15-2017 09:46 AM
I am trying to change the page order of a tab control, To control the pages.
It is posible to do this in any way?
thank you .
06-15-2017 10:16 AM
My guess is that since it's an enum, it can only be changed in edit mode.
06-15-2017 01:02 PM
This thread has some options for you:
https://forums.ni.com/t5/LabVIEW/How-to-change-tab-control-page-order-programmatically/td-p/1680334
06-16-2017 02:03 AM
I have already seen this topic but I have not found the solution I am looking for,
Especially that I did not find, an invoke node (method) "rearrange pages".
06-16-2017 02:24 AM - edited 06-16-2017 02:52 AM
Right click on tab control >> Create >> Invoke Node >> Rearrange Pages
As mentioned in the help, it requires VI scripting. I have never used this method.
06-16-2017 03:56 AM
Thank you I found it.
It is for what if the method is not used when the executing program?
06-16-2017 04:00 AM - edited 06-16-2017 04:02 AM
Hi Sarah,
you can use VI scripting to create new VIs or edit existing ones programmatically.
VI scripting is not allowed/possible in executables as you cannot change compiled code!
("Compiled" in the sense of "fixed in an exectuable", as LabVIEW always compiles the VI… Also executables call the RunTimeEngine which doesn't support scripting.)
