Ok, let me try to explain what I would like to do.
I have a test machine which can test 36 little electronic devices at the same time.
And I would like to visualize this test machine in labview to make it easy to operate for the testoperator.
The test machine is visualized by 36 blocks, each containing a string input field.
The test operator has to enter a serial number in each of the string input fields, and then push a button
to start the test.
Colors are used to show the status of each of the 36 devices. Green = test passed, red= test failed, blue = not tested yet,
yellow = test in progress, ect.
So what I need is an array of clusters, and in each cluster a string and somekind of colourfield. And then I would like to be
able to read the data (the serial numbers) in something like a while loop, but also I'd like to set the color of each field
independently, by using the array index (otherwise I must wire all of the 36 fields....)
This IS possible with Visual basic, Delphi, C builder, ect. (text based windows programming langues), so I expected this to be possible
in Labview also.
Mr. Drolet, I don't understand your argument. Nobody needs to show an array of 10000 controls, but an array of 10000 integers is quite feasable.
This will take a memory space of 10000 x the size of one integer.
A array of, lets say 50 visual controls on one screen can be needed in some applications. This will need a memory of 50 x the memory size of one control, including each of the property's of that control. This is less then the space needed for 10000 integers...
Thanks for your suggestion Mr. Drolet. But can I acces the color property of a colorbox if it's part of a cluster inside an array of clusters?
(as you might have noticed, I have experience with visual basic, but i'm new to Labview.)
