I tested an example and it worked. What I did is copied the code from Cont Acq&Graph (buffered).vi, and pasted it in the Function Generator.vi. Then, you are able to acquire on as many channels as you have available, and change the waveform coming out of the analog output channel while the program is running.
You can then add in the saving to file parts, as needed. Try this, and let me know if you can't get it to work. Thanks, and have a Great Day!
George M.
