10-19-2006 12:25 PM
10-19-2006 12:26 PM
10-19-2006 05:37 PM
10-19-2006 05:47 PM
Yes, Recursive File List.vi has shipped with LabVIEW since version 7.0. In version 8.2, I added the "pattern" input and put it in the File I/O > Advanced File Functions subpalette, along with a few other nifty VIs.
Enjoy,
-D
10-28-2006 11:15 AM
10-28-2006 12:32 PM - edited 10-28-2006 12:32 PM
The listbox function is perfect for this. If you have either 0 or more items or 1 or more items as the Selection Mode, then it will return an array that you can use with the Index Array function and the Item Names property node to get the selected values.
Message Edited by Dennis Knutson on 10-28-2006 11:33 AM
10-30-2006 05:55 AM
10-30-2006 08:25 AM
10-30-2006 10:38 AM
10-30-2006 10:57 AM
Why are wiring a value of 38 into the property node? I'll admit that I don't have 8.0 or 8.2, but in previous versions, that's not even close to valid. Right click on the node and select Help for Selection Mode. It will list the valid values. You can't just make up a value to write to it. And do you really need to set it on the diagram. Can't you just set it once on the front panel?
As far as the front panel path control, do you have the Browse button enabled and if so, what do you have for the Browse Options?
