03-13-2013 10:03 PM
I am programming labview to open some webpages and then record the activities of the mouse and keyboard. To make sure that it always start at the same size by full screen it. I use system exe vi and able to open the webpages, but i don't know how to full screen automatically. If you know how, please let me know. Thank you.
Son
03-13-2013 10:27 PM
I would create a shortcut to each of the browsers. Right-click each shortcut and set each one to run in a maximized window. Then you can simply use System Exec to run the programs in fullscreen mode by calling the shortcuts.
03-14-2013 10:59 AM
If someone moves or sizes it then it won't work. There must be a way with System exe in the Command line link \fullscreen. I'll try it out.
Son
03-14-2013 11:24 AM
There's certainly no standard full-screen command in Windows, because there's no such concept. That's something that each program decides for itself. You could try seeing if the different browsers can process command line switches to open at full screen or whether they have some addons (like GreaseMonkey) which will allow you to automatically run the full-screen command when the browser loads.
Some other alternatives:
