06-22-2015 05:28 AM
I have a power meter which provides two values, the power and wavelength simultaneously. So when I'am giving in the GPIB write command probe a joint command is not provided by ILX light wave. So how can i get the values simultaneously.
Please help
06-22-2015 06:02 AM
Hi perumpadapu,
you should read the manual of your device/software. There you should find the answer.
Or ask the customer support for that device.
As long as you don't even provide a name of your device we cannot provide much more help!
06-22-2015 08:22 AM
06-23-2015 11:13 PM
I using a National instrument GPIB to interface the ILX light wave power meter that measures the power and wavelength of laser beam. I read the manual but there the command for simultaneous measurement is not given. Please kindly help
06-23-2015 11:59 PM
06-24-2015 12:21 AM
The instrument measures and shows the power and wavelength simultaneously in seperate panels. But they had not provided the code for such a measurement. SO using GPIB write and read two times, for each command (power and wavelength) in a single while loop will provide the values simultaneously. Please reply
06-24-2015 12:28 AM
