06-01-2010 11:52 PM
06-02-2010 02:07 AM - edited 06-02-2010 02:08 AM
06-02-2010 02:24 AM
How to add this in waveform chart? I could not find that in chart...
06-02-2010 02:29 AM
06-02-2010 06:33 AM
Hey GerdW,
So far I know to display a subset of a larger set of data using cursor.. but no idea how to display the moving cursor Y value as per your suggestion.. I m using property node to get active plot information of X and Y scale and then .. formula i m using ..
Conv_X = (XScl_Max - XScl_Min)/PlotArea_Width;
Conv_Y = (YScl_Max - YScl_Min)/PlotArea_Height;
Graph_X = XScl_Min + Conv_X * (Mouse_X - (YScl_Left + YScl_Width));
Graph_Y = YScl_Max - Conv_Y * (Mouse_Y - (XScl_Top - PlotArea_Height));
inside formula node .... using above values I get the moving cursor value of Y scale.. as asked by thread author in starting ..
If there is some short way then i will like to learn it ..
Regards
HS
06-02-2010 06:39 AM
Hi HS,
do you use 2 different logins?
If you would enable/show the cursor palette of the graph you would actually see those values instantly...
When you want to calc with them you can use the properties of the cursor to get the x- and y-value! No calculation of graph size and so on needed...
