12-02-2010 11:07 AM
Hi, kind of new to Lab View but I am looking at some old Lab View code that has an 8 bit integer array with 8 values in it that is connected to a write DIO VI. Just a few questions, is there a way to tell if the write DIO VI is an Lab View Vi or a VI created by a user? Also the DIO card is the NI PCI 6533 card, 32 bits and there is the 8 bit integer array has 8 elements in it so would the the card first write out the first 4 elements at the same time (bits 0-7 first element, bits 8-15 second element, ect) and then the last 4 elements of the array or would the write DIO VI have to execute twice, once for the first 4 values and again for the last 4?
thanks
Solved! Go to Solution.
12-02-2010 12:06 PM
why don't you attach your old LabVIEW code?
Why don't you give the full name of the VI? Maybe it's an old "Traditional DAQ" VI?
"a way to tell if the write DIO VI is an Lab View Vi or a VI created by a user?"
Maybe by reading the context help for the VI? Sometimes there is a note who programmed the VI...
12-02-2010 12:16 PM
Thanks for the response, looks like it is a custom vi. Just wondering if you know what control to use to provide a user text list but have the selection be an integer value, like a drop down list box and the first selection is a 1, second a 2 and so on. I found the text control but looks like it sets a string value based on the selection.
12-02-2010 01:52 PM - edited 12-02-2010 01:53 PM
12-02-2010 03:26 PM
thanks for the additional information, I found a listbox that has I 32 in the diagram so thinking this will do what I want. Unfortunately the computer I am working on is at a different location than this one but will post a diagram when I get a chance.
