07-10-2014 03:51 PM
how do you find the group name and channel name of your TDMS file?
07-10-2014 03:56 PM
Here is my TDMS file also.
07-10-2014 05:39 PM
You should be able to do this pretty simply using the "TDMS List contents" VI, it takes in a reference from an open TDMS file and outputs a 1D array of the Group Names and a 2D array of the Group and Channel Names.
07-10-2014 07:27 PM
07-10-2014 07:52 PM
Were you wiring in a group name to the VI? You should just be able to wire in the TDMS reference and it will generate the 2D Array with all the channel names. Its pretty basic and should end up looking like:
Otherwise I tend to use another simple VI if I just want to look at the details of a TDMS File. Just build into an EXE and run it to view a TDMS file withou needing to worry about excel or anything.
07-15-2014 01:26 PM
This should find the names of the group and channels right?
07-15-2014 01:51 PM - edited 07-15-2014 01:52 PM
yep Im not getting the right names. here is the tdms file.
07-15-2014 02:28 PM
nevermind i used the file viewer.
