06-15-2015 10:16 AM
Hi all
I am using NI 6229 BNC DAQ and i have a flowmeter which is giving me pulse as output.
In attachment i am sending the datasheet of sensor.
How can i wire it to my daq
Please help?
06-15-2015 11:33 AM
The Digital Inputs of the 6229 probably want TTL signals (0v = off, 5v = on). If you provide 10v power to your sensor and use a "divide-by-2" resistor network for its output, you should have the digital signal that you need. Wire it to one of the Digital Input lines.
06-15-2015 11:33 AM
06-16-2015 04:44 PM
Hello, can you tell me which the expected output of this sensor is, is it Analog or Digital? This is because depending on that that’s how you wire the signal to the device.
06-16-2015 04:50 PM
06-16-2015 04:55 PM
06-16-2015 05:01 PM
