11-07-2005 11:58 AM
11-07-2005 12:43 PM
11-07-2005 12:46 PM
11-07-2005 01:03 PM
If you use shift registers as in Dennis's example, and this is a toplevel UI program, it is sometimes advantageous to place also the indicators BEFORE the event structure, right after the wire leaves the left shift register. It gets updated equally fast and has the advantage that it receives the correct default data even if the event has not yet triggered.
