02-13-2015 02:40 AM
hi
here how convert to below lab window ansi c program in to labview program ,please find any body sollution for this problem.
02-15-2015 06:14 PM
02-15-2015 10:49 PM
You convert it by writing the code for LabVIEW. There isn't a magical button to press to change the code. You could probably throw it into a formula node. But, it'd be a bit silly to do so.
Follow Mike's advice. Determine what you want the program to do. Once you know that, put in the work to write a new program and it'll be better suited to the task than "converting" an older code base that you clearly feel needs to be updated/changed.
03-30-2015 01:49 PM
The CVI program isn't very complicated. Shouldn't be too hard to convert to LabVIEW.
However, since it calls many external functions, if you don't have document about those functions, you can't convert the program to LabVIEW.
If you have a CVI compiler, you can convert it to a dll, so that it can be called in LabVIEW.
