11-11-2014 11:52 PM
Hello
I have a problem to concatenate a date array and numeric array. can you help me?
I want save Measurement of a sensor with save time in an excel (row 1 column1 save date and row 1 coulmn : save sensor data). but I cant save these two value seperatly(my clocks cant do it). now, I want concatenate them at first and then save them. is it possible?
Best Regards
11-12-2014 01:52 AM
Try the attached. You'll understand it as soon as you see it. If not, shout.
11-12-2014 05:48 AM
thank you Zwired1
your respons, really helped me.
just a problem is that, when I save data in the excel file, and read that a agein, my date change to unkown number. for example: 11/10/2014 change to 41953! in labview. do you know why this happen?
Best regards
11-12-2014 06:26 AM
Hi benzah1,
Attach your vi. It will be more helpful to solve the problem.
11-12-2014 06:46 AM - edited 11-12-2014 06:53 AM
The date showing as a number is an Excel display format problem.
41953 is the Excel number representing 10 Nov 2014.
In Excel you need to....
Select the cells containing the date
Format -> Cells -> Number -> Date
EDIT: This fix changes how the date looks when displayed in Excel. I am now not sure if your problem was when you display the result in Excel or after reading the Excel file back into LabVIEW.
Rod
11-12-2014 10:32 PM - edited 11-12-2014 10:35 PM
Thank you Rod
in excel, show correct date. my problem is when I display the result in labview again.
Hello Vij@y
which code is need? i just read a date saved in excel. and format is problem.
Best Regards
11-13-2014 02:18 AM
Hi Behzad1,
Attach the excel file and the code (after reading the Excel file back into LabVIEW).
