04-16-2010 02:05 AM
.exe can't run on computer without Labview. Is there any way? Thank you.
04-16-2010 02:07 AM
You need to install the LabVIEW Runtime engine for your specific LabvIEW version.
In the project window you can create an installer that includes the Runtime Engine (RTE).
Ton
04-16-2010 02:35 AM
"In the project window you can create an installer that includes the Runtime Engine (RTE)."
how? can show me the ways?
04-16-2010 04:03 AM
Dear Sir,
If you do not know how to compile runtime as a package, you can go ni website to download the runtime exe. If using Labview 2009 to compile, you should download Labview 2009 runtime. If using Labview 8.6 to compile, you should download Labview 8.6 runtime. I think the runtime installer is also available in you labview directory in your computer when you install labview on. Just run the runtime installer in your client computer and it should be no problem. You should also include all the dll if there is any to you cilent computer.
Thanks!
04-16-2010 06:54 PM
Refer to http://digital.ni.com/public.nsf/allkb/E09BA0E2F31D304F86256A640070058E on how to create additional installer.
Make sure that you include necessary driver.
