01-08-2015 03:24 PM
which toolkit will be used in interfacing matlab 2014a(64bits) with labivew 2014
01-09-2015 07:57 AM
I don't understand the question. What is it that you want LabVIEW and Matlab to do together? Are you writing a LabVIEW routine, complete with a LabVIEW Front Panel (UI) and LabVIEW code to control devices and collect data, and want to do some specific calculations in Matlab? Are you writing a Matlab application using GUIDE to create a Matlab GUI, and just want to use LabVIEW for interfacing with devices? Are you planning to use Matlab for everything except some small bit of code, say controlling one instrument, or doing one particular calculation? Were you planning to build a Matlab application (an Executable) or run Matlab in its default, "interpreter", mode? Similarly, were you planning to build a stand-alone LabVIEW Executable, or run LabVIEW in Developer mode?
01-16-2015 08:25 AM
Did you see my response to your question? I'm trying to offer you some help, but you haven't answered any of my questions, so I don't (yet) know what you mean. As they say, "The ball is in your court".
BS
01-17-2015 12:51 AM
sorry for late reply,
look, i'm basically working on matlab version which i have mentioned above. i just need to take my simulink model (real time signal) to the labview. i need a simulation interface toolkit for matlab 2014. but there is no toolkit present for matlab 2014.. what to do to bring my signal from matlab(simulink) to labview.
GOT IT?
01-17-2015 08:01 AM
Take a look at the MATLAB script node.
However, the options for input/output data types are limited.
01-17-2015 09:35 AM
He wants to bring simulink in, not matlab code. The MathScript Node you referenced, although by an incorrect name, is designed to bring in simple matlab code. He wants to run a simulation.
01-17-2015 11:09 AM - edited 01-17-2015 11:15 AM
Hmmmmm. Mathworks is behind? Ok ask them when the release is due.
Veristand is a rather nice HIL package and (with some experience) integrates with LabVIEW.
01-17-2015 08:29 PM
It's not MathWorks, it's the poster. They're looking at this:http://sine.ni.com/nips/cds/view/p/lang/en/nid/209048 They're ignoring "This is obsolete. Its functionality has been migrated to the LabVIEW Model Interface Toolkit."
That points them towards: http://sine.ni.com/nips/cds/view/p/lang/en/nid/211815
They can find several relevant links about it here:
http://digital.ni.com/public.nsf/allkb/D3F40C101B66128186257D020049D679
http://digital.ni.com/public.nsf/allkb/D70E74FDA37CD8E486257990000603A0
http://digital.ni.com/public.nsf/allkb/2AE33E926BF2CDF2862579880079D751
But, instead they want to sit around and wait for an obsolete toolkit to suddenly start being developed again.
01-17-2015 10:15 PM
i want to run my real time simulink model on labview (in real time), matlab script node you are talking about is difficult as compare to simulink.
01-17-2015 10:17 PM
yup you are right about veristand but i wanna know that it will give real time output on labview or what? i am confused about veristand
