02-09-2012 03:48 AM
hello
i want to find the type or model of the ni usb card and the serial number of it when i connected to the pc,
but how can i do it??can someone help me?
i have done something but the same error apears when i executate it!
THANKS!
Solved! Go to Solution.
02-09-2012 03:59 AM
Options are available in the Measurement I/O section. Try this property node.
02-09-2012 04:06 AM
well
if i put in hte way you have done, i have an error that is that the i/o in bad wired, and i cannot executate..
in the way you have done, i must say what device is, and what i want is to do it automatically.. do you understand?
02-09-2012 04:17 AM
You have to take the System property node and get the names of the device and then use the Device property node get the information you required.
02-09-2012 04:30 AM
hi!!!i take the name or type properly but i have an error with the serial number...the sserial number that appears in the measurament & automation...how can i take it???
02-09-2012 05:22 AM
do you understand me?
02-09-2012 06:33 AM
Can you post the VI that you made for reading the serial number?
02-09-2012 06:49 AM
weel, i think is good..
02-09-2012 07:35 AM
Try the attached VI. it should help you, its working fine in my PC and I have got the info regarding my simulated device.
02-09-2012 07:43 AM
this is all
