how can I send a strings present in a cluster to another cluster in an order according to order
I have a cluster of strings and I want to send it to another cluster according to the selection basis which will be done by me and again from the second cluster to the first one.
(3,022 Views)
Your question is not clear. How do you select the string in a cluster? Please show the cluster format
(3,018 Views)
This is the format but in the second cluster it should be in the form of strings
(2,999 Views)
I guess you are a very beginner, since you seem do not know there is a thing called block diagram in LabVIEW 🙂
Take some of the free tutorials...
http://www.ni.com/f/students/12/7052/en/
edit: based on your Front Panel what you showed, you do not have a cluster with strings. You have two clusters with Boolean buttons...
edit2: you could even use an array as output, since the types are the same, you do not need a cluster:
And if you want to get the Bool texts:
(2,983 Views)
If you want to get only the Boolean text of the button which you clicked on it, you can just use an Event structure:
(2,961 Views)
