how can I sample 1 KHz asynchronous data using a PXI 6229
I have a 1 KHz data flow demodulated from a radio and want to compare it with the modulated data. The radio receiver is connected to a PXI-5650 generator. Checking the data with a scope I see the pattern demodulating. Just not sure how to optimize the dio (PXI-6229) checking  the data. Doing a sort of simple BERT and the longer  the record the better.
Message 1 of 13
(3,048 Views)
  • Where's your VI?  (Don't attach a picture, that doesn't help us much).
  • When I search for BERT, I found Ernie.  Sometimes we can figure out cryptic questions from the attached code ...
Message 2 of 13
(3,007 Views)
Ernie? Not Albert? 🙂
(I guess BERT stands for "Bit error rate test").
Message 3 of 13
(3,001 Views)
Bob
Sorry the question was a bit vauge. A BERT is a bit error rate tests.
https://en.wikipedia.org/wiki/Bit_error_rate
A comman metric used to confirm a radio transmission.
Message 4 of 13
(2,962 Views)
Could you not create a task to measure the frequency and see when it increases then count that?
Message 5 of 13
(2,943 Views)
The frequency would not be consistent mesuring the data stream. I would vary with the data pattern. And obviously not work with all 0's or all 1's. I think I need to trigger a sampling clock starting with the first data transition.
Message 6 of 13
(2,920 Views)
Here is a diagram of what I need to do.
Message 7 of 13
(2,902 Views)
Message 8 of 13
(2,881 Views)
Yes, thanks. That's a bit different I think. It's doing a BERT on deserialized (//) data. My data is serial modulated, then demodulated to serial. I would like to check the demodulated serial data against the data that was modulated (i.e. PRBS, all 1's, ....etc). But need to sync the DAQ to sample deterministically.
Thanks, Michael
Message 9 of 13
(2,839 Views)
So is your question specific to synchronization?
Message 10 of 13
(2,823 Views)
