06-20-2012 07:35 AM
i have string starts with #456 then some values and i want to remove #456 and using the other values
how can i do that?
thanks in advance
Solved! Go to Solution.
06-20-2012 07:42 AM
Make an array containing string values.Then you can use index array function and remove the particular one from the respective index.
look at programs>>Arrays in function pallete.
NB:Also, please give an informative heading to your post about the content inside.
06-20-2012 07:55 AM
You can use the match pattern function wich would do the job just fine.
06-20-2012 08:07 AM
how can i do that?
thanks in advance
If you are always going to have the #456 at the beginning or if it is always going to be four characters then you could use the string subset.
06-20-2012 08:19 AM
Make an array? Based on what criteria? Your suggestion makes no sense whatsoever.
06-20-2012 09:40 AM
thaaaaaaaaaaaaaaaaaaaaaaanks
06-20-2012 09:41 AM
You are welcome.
