help with Array to spreadsheet string
James.Morris a écrit :
@ben64 wrote:
Here are 2 ways to do it without loop.
Ben64
EDIT: just realized you want a comma to separate rows, replace the tab by a comma in solution 1. (solution 2 will not work in this case)
What's up with that funky pattern replace VI? I haven't seen that before. This would be my version:
Freelion, it does have a space after the comma because that's what his example output had from OP's original post. The space can be removed, or any delimiter can be put in its place.
Funky? Search and Replace Pattern.vi from tha Additional String Functions palette. This vi accept regular expressions instead of a string as a search pattern. A lot more powerful when you're familiar with regex.
Ben64
Message 11 of 14
(1,102 Views)
Ben64
I don't do a whole lot with string parsing (I try to stay away from strings when I can), so I guess it's one of those things that's just evaded me for all these years. Thanks for enlightening me!
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 12 of 14
(1,085 Views)
Thanks everyone for contributing to this thread. I have marked ben64's reply as the solution as that was exactly what I was looking for.
Message 13 of 14
(1,079 Views)
Here is also my new version below;
If you do not want space after comma, remove the space from string constant which is right below end of line constant.
Senior Software Developer
Message 14 of 14
(1,068 Views)
