02-25-2016 10:06 AM
hi comunity i have a problem with matab script of de labview , i have this problem :
Error 1047 occurred at LabVIEW: LabVIEW failed to send variable to the script server. Server
Possible reason(s):
02-26-2016 02:59 PM
We have a few documents that mention possible reason of why this error happens, could you see if either of the following apply to what you are seeing.
http://digital.ni.com/public.nsf/allkb/8BEBC0C86541224286257AF300561B5E?OpenDocument
http://digital.ni.com/public.nsf/allkb/2B3FF46C8512C4F786256CF30071BE53?OpenDocument
09-13-2018 03:05 AM
hi,
now,l meet the error 1047,but l can not solve this problem, may you give me some suggestions?
thanks
09-13-2018 06:09 AM
Without some specific information, the suggestions will be the same as two years ago. Have you read those documents?
