03-21-2013 04:39 AM
Hi
I was working on the gyroscope with arduino on labview using I2C,to read the data from ITG3200 I'll have to read 2 addresses ,how can I concatenate them ?
03-21-2013 08:05 AM - edited 03-21-2013 08:05 AM
Is this what you mean?
03-21-2013 09:21 PM
so this will basically concatenate it,and make it a 16 bit address ?
The other problem I was facing was that when I ran the program it kept on showing me an error ,arduino was not recognised,despit getting recognised on the measurement and automation explorer and I'd uploaded the basic (LIFA base)arduino code also
03-22-2013 07:59 AM - edited 03-22-2013 08:00 AM
No, my code was showing how to send two, 8-bit addresses. (Your original question said that you needed to read two addresses) Are you sure the address is 16 bit? The control on the Arduino VI is an unsigned, 8 bit integer.
03-22-2013 12:58 PM
Hi
Oh its because Id just used the 8 bit address that's why.The thing with the gyro Im using gets data from two addresses ,a high and a low ,i just need to concatenate together so that I can display.
