03-09-2007 11:50 AM
03-09-2007 01:15 PM
03-09-2007 05:45 PM
03-09-2007 06:31 PM
03-10-2007 08:30 AM
03-10-2007 08:55 AM
You're not explaining your problem very well. There are a large number of shipping examples for acquiring data from a DAQ board. If you have correctly installed the drivers that Christian pointed out to you, you should have no problems getting started with the examples or the DAQ Assistant. You should also check out http://zone.ni.com/devzone/cda/tut/p/id/5434. If you have done some of this, provide more details as to what your problem is. Do you get an error when you run your program? if so, what is it. Do you only get 1 signal instead of 2? Do you get two signals but don't know how to plot them on an XY Graph? Can you post the code you've written and are having problems with.
It is better to provide too many details than not enough as you have done.
If you are having problems with English, you can also post your question in Spanish. There are many forum users who will be able to understand (not me, unfortunately), but it might take a little longer to get a response.
03-12-2007 11:56 AM - edited 03-12-2007 11:56 AM
I only get 1 signal instead of 2 and dotn't know how to plot them on an XY Graph
bueno si yo solo puedo obtener una señal en lugar de dos cuando intento obtener dos señales en lugar de una el programa no me lo permite solucione ya este problema con un lazo cae pero al hacer esto obtengo ya dos señales pero no al mismo tiempo yo lo que requiero es obtener dos señales y graficarlas an un plano xy trazando una curba punto a punto es decir como trazar el grafico de una ecuacion de segundo grado en el plano cartesiano
Message Edited by Support on 03-12-2007 02:20 PM
