01-17-2007 03:16 PM
01-18-2007 02:25 PM
01-18-2007 02:37 PM
Hi Chris,
Thanks for the reply.
I'm attempting to get two plots onto one graph from different cases. The 2r data is lat and long for a flight path. The 13r is lat and long for a target. As the data is read from file, I want to show the flight path (2r) plot in progress, when a 13r is read, I want the target to show up in the same graph. How do I pass the data out of the case structure such that two plots are created onto the single Graph.
01-18-2007 04:48 PM - edited 01-18-2007 04:48 PM
Here's a very simplified example of how I would start to approach your problem. You build a multi-plot graph as an array of clusters. So, you could have shift register for each cluster and in each of the cases, you would build up the data for one of the plots and just pass the shift register through for the other plot.
Message Edited by Dennis Knutson on 01-18-2007 03:49 PM
01-19-2007 08:18 AM
Dennis,
Thanks for the suggestion and example description. I'll let you know how this works out.
01-19-2007 10:38 AM
01-19-2007 11:26 AM
01-19-2007 03:10 PM
Dennis,
Thanks to your help I was able to get something that works for large file.
It may not be pretty, but it works and I can adjust the chart history size to control memory.
Attached is a picture of diagram.
Thanks again
